battery for Tembr-1
lordbizarre | 13.07.2012, 09:34 | |
ID пользователя #2427Зарегистрирован: 22.02.2011, 16:44 Местонахождение: Brussel, Belgium Сообщений: 43 | just bought a TEMBR-1 WahWah(not sure about this model name , comes from seller and has no brand and/or model numbers ) . After study the circuit I've a feeling that this WahWah has to run on two 9V battery's instead of one now , one for the circuit and one for the lightbulb for pedal reaction ? More info about this Tembr-1 also very welcome ! thx !
Alex | 13.07.2012, 10:44 | |
| Гость | Maybe, two 4.5V battery?- [link] , [link] , but i not sure. | Наверх | |
Les | 13.07.2012, 10:52 | |
| It quite possible, that two 9V batteries were used. I can/t remmember right now, but I think, that I saw some devices, that used two batteries.
shlepakoff | 13.07.2012, 14:58 | |
| ilya
| lordbizarre, we had a post about this pedal with detailed photos that you can see here: [link]
according to the owner, the unit takes two 9V and one 4.5V batteries.
lordbizarre | 17.07.2012, 18:21 | |
| ID пользователя #2427 Зарегистрирован: 22.02.2011, 16:44 Местонахождение: Brussel, Belgium Сообщений: 43
| OK ! thx !!! I compared the digpic's from the other one and noticed that mine is a little different ( no variable resistor R4 and otherwise placed components).I've to check-out my Tembr-1 since it's rebuild for only one 9V battery and no 4,5V battery...if I find some time ...It's possible that it can run on one 9V , if the bulb is changed from aproximately 3V to 6V or so. I found some 1977 marks on the pedal so I presume it must be from arround that year.
