Question about Formanta wiring
OveA | 25.11.2017, 19:16 | |
ID пользователя #9227Зарегистрирован: 15.11.2017, 13:03 Местонахождение: Viljandi, Estonia Сообщений: 160 | Hi!
I´m restoring formanta guitar. One guy decided to solder it cooler and messed all up....Now i got everything back together and even fuzz is working... I drew red circle around my problem. Does capicators and resistors goes between hot and switch or from switch/hot point to grounding. I tried several ways, but non of versions seems right. I don´t have three bottom switches and trying to built temporary solution.
Thank you for answer!
OveA | 26.11.2017, 09:14 | |
| ID пользователя #9227 Зарегистрирован: 15.11.2017, 13:03 Местонахождение: Viljandi, Estonia Сообщений: 160
| Nevermind, i got it.
Yesterday i was tired and sleepy, today i used some logic and everything is working. | Наверх | |
Gess | 26.11.2017, 09:23 | |
| How do you fuzz? To play, say as Panther or King Crimson? Really? )))
StariyDed | 26.11.2017, 09:56 | |
| Please note that the numbering of the parts of the wiring diagram does not correspond to the numbering of the parts on the circuit diagram. Namely - on the wiring diagram the numbering of R13 and R15 needs to be interchanged. The output signal is removed from R15. Good luck! | Наверх | |
OveA | 26.11.2017, 10:32 | |
| Gess Цитата ...
Well fuzz is not something special but most important was to get it work
OveA | 26.11.2017, 10:41 | |
| StariyDed Цитата ...
Yes, i figured that out. Problem was only with marked area but it was so simple mistake I woke up early morning and after one coffe i got it. Those tumbler switches are just for testing and little video, didn´t want to wake up neighboards.
[ Редактирование 26.11.2017, 10:42 ] | Наверх | |
SPA08.04. : 06:17кучно пошли
